Include external .bsp file at compile time?
![Zoot](https://forums.parallax.com/uploads/userpics/559/nW4UO23UEIWZ4.png)
Can you include a document into a .bsp file at compile time? I'm working on a multi-slot project and I basically want to include all my constant and I/O defintions so I don't have to cut and paste changes.
E.G. can I something like the example below. I checked documentation and didn't see any mention of this for the Stamp Editor,
And both programs would have the defs code inserted on-the-fly at compile time.
Or can anybody recommend any tricks for doing this quickly -- I've changed around some pins and some of my constants several times, and each time I end up cutting-and-pasting my master definitions to 6 or 7 programs.
'---- a file called "mydefs.bsp" ------ Slot CON 127 'spram addresses Task CON 72 State CON 70 IRk CON 590 'some constants LEDs VAR DIRA 'some i/o LEDcolor VAR OUTA 'etc....... '---- a file called "MyProgram.bsp" in the same folder ' the line below would be equivalent to actually cutting and pasting ' the defs from above into the document at compile time #INCLUDE "mydefs.bsp" 'or some such compile syntax Work VAR Word ' Buffer VAR Byte(5) ' ' etc....... '---- a file called "SomeOtherProgram.bsp" in the same folder #INCLUDE "mydefs.bsp" ' etc
csavage@parallax.com
