Argg! Why won't Stamp DAQ read values greater than 255?
Hey guys,
So pretty much I'm saving 400 values, with each value between 0-4095. I'm saving them as words, in EEPROM locations of 0-800 (step 2). After all of my data is saved (I tested by saving 4095 to all 400 locations), I run the attached program (dump test 001), which is a modified version of the example code that came with DAQ. I then go into DAQ, check the "download data" box, and click the "connect" button. DAQ then quickly reads all of the values in EEPROM locations 0-800 (step 2), and dumps it into a row.
Now here' the problem. All of the values are 255, instead of 4095. I've messed with the example dump code, and made all the variables words, hoping they would be large enough to hold the number "4095".
Does anyone know how to fix this problem?
Matt
Matt
READ/WRITE are by default byte sized. To handle multibyte values such as word use something like:
READ X,StoreVal.LOWBYTE
READ X+1,StoreVal.HIGHBYTE
Regards
Adrian
What Adrian said is correct, as far as it went. However, in PBASIC 2.5 there is another option as shown by this example extractred from the PBASIC Help File:
quote
' {$PBASIC 2.5}
idNum VAR Word
score VAR Byte
ID_Rec DATA Word 1125, 75 ' Store multiple items
Main:
READ ID_Rec, Word idNum, score ' Read multiple variables
end quote
As you can see, the new sub-parameter WORD was introduced as an optional part of the READ/WRITE command, such that WORD-sized varaibles can be read and written more easily. Adrian's example will work on any PBASIC level.
Bruce Bates
<!--StartFragment -->
Matt
