Is there an Efficient way to get an 'Earth' Ground?
I am working on a design that requires an Earth Ground.
My initial plan for the power supply of the project was to use an ATX (pc) power supply:
http://www.newegg.com/Product/Product.asp?Item=N82E16817174025
....But, as far as I am aware, Earth Grounds come from attaching to pipes that go into the ground.
Would an ATX power Supply provide a sufficient Earth Ground, or should I consider another design?
Shaun
Post Edited (Steel) : 5/15/2006 5:58:47 PM GMT
Shaun
So, what is your project? I'd like to hear more about this before you start wiring it up.
kenjj
