BS and RS232 handshaking
Hi!
I have a very urgent problem. I am using a BS2px to collect temperature data and send it through RS232 to Agilent VEE. I can recieve the message but it is unreliable, errors occur. I am suspecting that my program, VEE, needs a handshake befor exchange of data.
How do i make the BS to use handshake and how does the code look (if needed)?
(the optimal situation would be that Agilent VEE program sends a request for data, and BS sends it afterwards. I have tried this but the message to the program is unreliable without the handshake...)
HELP,
Walter
HELP,
Walter
·· If you look in the BASIC Stamp Syntax & Reference Manual or in the Editor Help File you will find the information in the SERIN/SEROUT section.· There is even example code there.
csavage@parallax.com
With the situation you described as optimal ( ie a query and response situation ), there shouldn't be a problem, even without handshaking.
Things to check would include:
Is the Stamp waiting for the Agilent serial string; that is, are you using the WAIT modifier with the serin?
Is there a brief pause before the Stamp starts sending data back?
Are you trying to communicate at too high a speed? Start with 2400 baud and move up from there.
Cheers
