DOS Editors
Eeh...I have an old 386 on my workbench in the garage (my parents won't allow anything else there) that I wish to use to program my Stamps.
I have an old DOS editor, but it cannot recognize the hardware when connected, although all my other comps can, running the newer Windows Editors
Rafael
PS: I had it working a long tim ago, but it apparently doesn't like new stamps
Rafael
Jon Williams
I actually have the right version, but I want to try downloading the software again, only I can't find them.
Did you guys at Parallax take them off the site?
Rafael
Jon Williams
Hm...it still cant find the Stamp. I put it on this comp (XP) to compare it to the Windows one...That one can identify the Stamp, the DOS one can't. How do you tell the DOS Editor which port it's supposed to look on? Or does it check all of them automatically?
Basically my project is stuck until I get that to work because I dont want to carry stuff back and forth once I start building the next part of the board.
Rafael
Post Edited (flyingfishfinger) : 5/16/2006 3:49:38 AM GMT
Which Stamp are you using?
And which port on the PC?
(COM1/COM2, and is it a 9pin or 25pin D-sub)
Don't visit my new website...
I have 2 COM ports, the Windows Editors all use COM1 (This is the machine with WinXP)
The other comp (the one with DOS) has 1 serial port, which I defined as COM1
All of them are 9-pin.
Rafael
Jon Williams
It even ran in XTM(an IBM PC XT emulator I sometimes use on my Psion netBook), but as serial ports didn't work correctly there, I never used it for programming the BS2p that way.
(I still have it on the virtual 'boot disk' for the emulator as it's such a compact and capable editor)
Rafael
check the serial port for proper electrical operation.
It happened to me with the fisrt BOE and an old Olivetti Pentium I,
the serial port was damaged in an other experiment and the result was
hardware not found, both in win 95 and in dos environment.
hope this helps..................
Stefano Caruso
