Voltage Regulator Polarity
Is there any way to prevent damage to a voltage regulator if the polarity is connected backwards? I just had a 7805 die by useing a wall transformer that had the positive terminal on the outside and the negative on the inside. That was just uncalled for. By now I know to check every single time.
I've also seen similar designs with just a diode feeding the input side of the regulator (D1 in the circuit above) and D2 and D3 are omitted.
*** Post Edit ***
If you choose to use a F-W-B -- then·its input must be isolated from the rest of the circuit/ry.· I hasten to add that F-W-Bs work with DC just as they do with AC.· You just have to keep your head about you.· Dwg attached.
In matters such as this, the best (and most under-utilized) test instrument you have is·your lookenpeepers, but you can't beat a DMM.· In carpentry they say, "Measure twice, cut once."· In electronics, I say, "Assume nothing, get the voltmeter."
Post Edited (PJ Allen) : 5/14/2006 11:37:01 AM GMT
The bad news....
These babies have a fourth wire for sensing low input voltage and it seems that 4th one is NOT protected.
There is virtually no reversed polarity protection and they fail by allowing a full voltage to pass.
The good news....
They output a full 1 amp and can go very, very low [noparse][[/noparse]down to nearly 2volts]. So you get the most out of battery options.
Of course, using a polarized plug or battery holder will get you the most power because all diodes have that wasteful voltage drop, even the Schottky Barrier diodes.
If you must use diodes in battery applications, consider the Schottky's. Only 0.25 voltage drop. They are rated to at least 3 amps.
Post Edited (Kramer) : 5/14/2006 12:50:27 PM GMT
