Propeller I/O input impedance — Parallax Forums
El PaisaEl Paisa Posts: 375
edited 2006-05-15 05:58 in Propeller 1
Does any one have an idea·what the Propeller input impedance I/O pins are?.
Both off and on states.
Not only the resistive component but the input capacitance as well?
I am looking for something like the thevenin or norton equivalent circuit.
This may have a critical effect if a large series resistance is used when connecting a 5V circuit.
    edited 2006-05-14 02:56
    You should not connect to a 5v circuit directly; if your source input is 5v level then you should limit th current into the pin with a 1k - 10k resistor.
    Jon Williams
  • cgraceycgracey Posts: 14,319
    edited 2006-05-14 05:28
    In input mode, the I/O pins have nearly infinite resistance and about 6pf of capacitance. There are clamp diodes that limit pin voltage·from·VSS-0.4V·to VDD+0.4V.
    El Paisa said...
    Chip Gracey
  • El PaisaEl Paisa Posts: 375
    edited 2006-05-15 01:48
    My only concern is the time constant introduced to the input.
    With a 10k resistor and a 6pf input capacitor, the time constant is 0.06 microseconds not to small compared with a clock frequency of 80Mhz (0.125 microseconds).
    Now with a series resistor of 100k and input capacitance of 6pf, the time constant is now 0.6 microseconds.
    For some high frequency applications specially video, this time constant will introduce a considerable delay.
    Consider the solutions in 'The Art of Electronics' for going from +5 to +3.3. There are specific conversion chips available. Refer to Chapter Nine.
    The clamping diodes appear to have only so much capacity to bleed off the excess voltage. There is a thread [noparse][[/noparse]about May 5th] that discussed this and provided some data. 100k might work, if the frequency is appropriate; but how can one be sure?
