strange behaviour of the PBasic Editor
HI everybody
Some weeks ago due to a mess in the HD of my PC, I had to reformat and reinstall all the programs,
I did everything as usual, but this time when I launch the editor, it shows an error message Disk not Found, Impossible to locate the disk in the unit, please insert a disk in the unit .
pressing Undo or continue two times, the Editor opens regularly and works fine, pressing try again does not work.
Any suggestion??
Thanks in advance
Stefano Caruso
P.S. the Propeller Tool has exactly the same problem, instead the Stamp Logic Analizer Program and the SX Editor starts flawlessy,
Any suggestion??
Thanks in advance
Stefano Caruso
·· Both the Stamp Editor and the Propeller IDE have a built-in "explorer" which allows you to navigate and view files in the pane on the left.· This built-in explorer has to essentially get the information for all attached drives and you must have a Memory Card reader or a similar device for which a drive letter is reserved but which no volume information exists.· Is this the case?· If so you can simply cancel past it.· If not let us know.
csavage@parallax.com
Alohas,
Robert
This is another astonishing performance of that marvellous world that is Parallax.
I didn't think that in the package of the new HD there was also a 1Gb. memory disk and that this memory disk caused the problem.
problem solved
Stefano Caruso
