Hyper Terminal with Serout
I can't·get hyper terminal to receive bytes sent from BS2 executing SEROUT commands, although I can get the bytes in the debugger fine.
I am using Pin 16. I have tried various baud modes to no avail. 8 Bits, no parity , 1 stop bit, no handshaking. I am using just the plain download cable with no extra hardware.
Does hyper terminal work with bs2 (pref using download cable), and can anyone give an example of setting please?
Note: Hyper terminal does work with a non parallax chip on this machine.
Post Edited (PJ Allen) : 5/11/2006 2:32:19 PM GMT
Sid Weaver
Do you have a Stamp Tester yet?
Without the capacitor, Hyperterminal brings the DTR line high and keeps it there as long as it is "connected", and that holds the Stamp in reset.
Tracy Allen
www.emesystems.com
How fare ye then, Mike Collier?
I tried the tws9600.ht file but that didn't seem to help me, maybe I wasn't using it right, I just opened it in H.T. applet viewer.
I am now trying to read data into an existing application that reads from the COM port, that application is getting inconsistent readings from the stamp and laplink cable - so I will dig into the source. Ultimatly it is this application that I want to get working correctly. AFAIK this wouldn't affect DTR line would it? it just writes and reads from a com file/port.
If anyone has delphi code for reading code from COM & Stamp that would useful too, hopefully it is just a setting problem since non stamp stuff works ok....
Any ideas welcome...
I have also had a closer look at the board that the bs2 came on (bought in uk) its not a parallax board and doesn't seem to have the capacitors tracy mentions (just one for regulating the power from what I can work out).
Seems I need to get some decent hardware and maybe things will work out for the best.
Thanks for the help, much appreciated.
