dead copper on pcb polygone plane
I designed a two-layer pcb and added a ploygone plane on both component
and solder side. The top plane connects to VDD and the bottom plane
connects to GND.
Is it wise to leave dead copper areas in place or should I remove these?
regards peter
connects to GND.
regards peter
They would act as a bypass capacitor, so I would think it would be better to leave them.
G
any possible signal degradation? A ground or VDD plane
would decouple two signals, but how about dead copper?
regards peter
dead copper removal is an important issue specially for designing highly populated, only-SMD boards. @ http://www.geda.seul.org/mailinglist/geda-user17/msg00105.html
It is considered a "bad thing" to have dead copper in your PCB @ http://groups.google.com/group/sci.electronics.design/browse_thread/thread/1b02ab3a0bcc1daa/ae6e8041f64e0255#ae6e8041f64e0255
engineer, fireman, bowler, father, WoW addict [noparse];)[/noparse]
·· I'm sure you already thought of this, but unless your mounting holes are isolated from the planes, if you use a metal screw through the PCB it·could short both planes.· This is especially true if you're mounting to standoffs.
csavage@parallax.com
Thanks for the links.
I will connect any dead copper manually or remove it.
Chris,
my mounting holes are actually plated through holes of 4mm
which do not connect to anything.
regards peter
What is 'the best' density for polygon planes?
I currently have a 50% fill (20 mil grid with 10 mil tracks)
Clearance between polygone and tracks/pads is 15 mil.
See attachement.
regards peter
