My BS2 Xylophone robot.
A few months ago, I saw a video for a robot called the Conraptophone, and it inspired me to try to build my own. While the original was pretty cool, I thought I could do better.
Well, I think I did! (video)
As you can see, I ran out of room on the BOE breadboard, so I bought a bigger one to use for the control buttons. The black button wipes the song in memory, and the red buttons add new notes to the end of the song. When the BS2 is reset, it plays whatever song is in memory.
Since making the video, I tweaked the timings a bit to let it go faster.
Current plans include a backspace key and a "rest" key, and maybe some potentiometers for tuning, but I'm already using 13 out of 16 pins
, so first I'll probably have to rig up some way to reduce the number of pins needed to control the buttons.
Post Edited (Bergamot) : 5/10/2006 6:27:55 AM GMT
, so first I'll probably have to rig up some way to reduce the number of pins needed to control the buttons.Post Edited (Bergamot) : 5/10/2006 6:27:55 AM GMT
One thing though, is that yuo might want to place the two 'arms' closer together.
That way you get a different arch which will make it possible to hit closer to the center of the outermost notes.
As for I/O-pins, you may want to splitting the keyboard into 'rows' and scan them that way.
That should save a few pins.
Don't visit my new website...
Something kids would love!
Can you build "live" button actions? Like an organ-like device.
good job!
Steve
·· In the video it shows him pushing buttons for the corresponding note after the main sequence is done so that should be supported.
csavage@parallax.com
· Where's the program?
' {$STAMP BS2} ' {$PBASIC 2.5} 'Declare Variables i VAR Byte songLength VAR Word currentNote VAR Word servo12pos VAR Word servo13pos VAR Word servo14pos VAR Word servo15pos VAR Word 'Declare Constants servo12rest CON 775 servo12note1 CON 835 servo12note2 CON 794 servo12note3 CON 749 servo12note4 CON 708 servo14rest CON 590 servo14note1 CON 653 servo14note2 CON 611 servo14note3 CON 570 servo14note4 CON 528 servo13rest CON 570 servo13down CON 537 servo15rest CON 540 servo15down CON 507 'Begin Program READ 0, Word songLength counter VAR Word counter = 2 servo12pos = servo12rest servo13pos = servo13rest servo14pos = servo14rest servo15pos = servo15rest FOR i = 1 TO 10 PULSOUT 12, servo12pos PULSOUT 13, servo13pos PULSOUT 14, servo14pos PULSOUT 15, servo15pos PAUSE 20 NEXT DO IF (counter) <= (songLength * 2) THEN READ counter, Word currentNote IF currentNote > 400 THEN IF currentNote < 1000 THEN servo12pos = currentNote ELSEIF currentNote < 2000 THEN servo14pos = currentNote - 1000 ENDIF ENDIF FOR i = 1 TO 10 PULSOUT 12, servo12pos PULSOUT 13, servo13pos PULSOUT 14, servo14pos PULSOUT 15, servo15pos PAUSE 10 NEXT IF currentNote > 400 THEN IF currentNote < 1000 THEN servo13pos = 537 ELSEIF currentNote < 2000 THEN servo15pos = 507 ENDIF ENDIF FOR i = 1 TO 5 PULSOUT 12, servo12pos PULSOUT 13, servo13pos PULSOUT 14, servo14pos PULSOUT 15, servo15pos PAUSE 20 NEXT servo13pos = servo13rest servo15pos = servo15rest FOR i = 1 TO 5 PULSOUT 12, servo12pos PULSOUT 13, servo13pos PULSOUT 14, servo14pos PULSOUT 15, servo15pos PAUSE 20 NEXT counter = counter + 2 ENDIF IF IN0 = 1 AND songLength < 600 THEN songLength = songLength + 1 WRITE 0, Word songLength WRITE (songlength * 2), Word (1000 + servo14note1) ENDIF IF IN1 = 1 AND songLength < 600 THEN songLength = songLength + 1 WRITE 0, Word songLength WRITE (songlength * 2), Word (1000 + servo14note2) ENDIF IF IN2 = 1 AND songLength < 600 THEN songLength = songLength + 1 WRITE 0, Word songLength WRITE (songlength * 2), Word (1000 + servo14note3) ENDIF IF IN3 = 1 AND songLength < 600 THEN songLength = songLength + 1 WRITE 0, Word songLength WRITE (songlength * 2), Word (1000 + servo14note4) ENDIF IF IN4 = 1 AND songLength < 600 THEN songLength = songLength + 1 WRITE 0, Word songLength WRITE (songlength * 2), Word servo12note1 ENDIF IF IN5 = 1 AND songLength < 600 THEN songLength = songLength + 1 WRITE 0, Word songLength WRITE (songlength * 2), Word servo12note2 ENDIF IF IN6 = 1 AND songLength < 600 THEN songLength = songLength + 1 WRITE 0, Word songLength WRITE (songlength * 2), Word servo12note3 ENDIF IF IN7 = 1 AND songLength < 600 THEN songLength = songLength + 1 WRITE 0, Word songLength WRITE (songlength * 2), Word servo12note4 ENDIF IF IN8 = 1 THEN WRITE 0, Word 0 songLength = 0 counter = 2 servo12pos = servo12rest servo13pos = servo13rest servo14pos = servo14rest servo15pos = servo15rest FOR i = 1 TO 10 PULSOUT 12, servo12pos PULSOUT 13, servo13pos PULSOUT 14, servo14pos PULSOUT 15, servo15pos PAUSE 20 NEXT ENDIF LOOP▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Mark
-Joe
