Saving programs
I am using the Parallax PDB to run the SX28.· after I get done with the program, I select Run and Run, when I turn the PDB off I seem to lose the program.· What am I missing here?·
John
John
If you are using the SX-Key for a clock source, when it loses power it does not provide a clock again when it is powered up.
You can use RUN->CLOCK to enable the SX-Key clock after it loses power.
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
COMING SOON "SD DATA LOGGER" www.sddatalogger.com
"I reject your reality, and substitute my own." Mythbusters
1+1=10
Bean.
