Serin/Serout Commands
I set up the Schematic like it is in the Parallax book. I have done Serin/Serouts before, but I am having trouble doing it this time. I took all of my code, and just made a simple counter, and tried to get the other stamp to recive the number as it counted. My actual project involves 2 RFID Readers sending their tagNum they pick up over to the other stamp, which displays a speed limit based on that tag number, and as you turn a voltmeter, another display on that stamp goes up or down. It is designed so if your car drives over an RFID tag in the road, it can show you the speed limit of that road. The other RFID reader reads tags on a keychain and if the kid's keychain is read, the Speed of the car can never be greater than the speed of the road. We are working now with tri color LED's so that if they car is under the speed limit it is gree, if it is at the speed limit it goes orange and if you go over it goes red. With all of that code, I couldn't tell if it was something in my code messing up the SERIN, SEROUT commands. So I designed this simple code, and it still didn't work
x VAR BYTE
Main:
SERIN 15, $2d, 600, Main, [noparse][[/noparse]x]
PAUSE 2000
DEBUG X, CR
GOTO Main
x VAR BYTE
Main:
AUXIO
x = x+1
SEROUT 15, $2d, [noparse][[/noparse]X]
GOTO Main
x VAR BYTE
Main:
PAUSE 2000
DEBUG X, CR
GOTO Main
x VAR BYTE
Main:
AUXIO
x = x+1
GOTO Main
Jon Williams
Jon Williams
