BS2 and transistor help.
Joe M
Hello Everybody - I want to drive 4 LEDs with a transitor controlled by the bs2... So I hook up a 2n3906 to the bs2, with the power coming from VDD on the BOE. Everything here works fine, although 2 leds is all I can power with VDD.
Everything there works fine, but if I use say 8v going in to the positive on the transistor instead of vdd it doesn't work right. Is my problem simply that the 2n3906 won't switch 8volts?
-Joe
-Joe
If I had to hazard a guess, making completely unjustified assumptions about how you have it wired up, it sounds like a common ground issue.
Or, it could be that the platypus is not facing the right way....
Or the horizontal jackstaff limiter relay is sticking....
So after I posted it I took a look back at my breadboard and its a ground issue. Thank you guys for the info.
-Joe
You will need to use an NPN (2n3904) transistor to do what you want with an 8V supply.
To see why this is, check out the link below...
http://forums.parallax.com/showthread.php?p=552072
Beau Schwabe
IC Layout Engineer
