Noise on TV output
I have moved this question from my former thread, where I was asking about PAL mode.
Now I get the picture but I get as well·a lot of noise over the picture.
By noise I mean shadow lines moving on top of the picture.
In the TV Terminal demo the noise makes the text to tremble slightly.
The noise is strong enough to make the TV mode pretty annoying.
I have tested the video·demos with two different Propeller configurations, one my own, and the other the Propstick.
I have changed the video cable and used two set of resistors. No changes, the noise is still there.
Do you get a clear, solid·picture ?
I saw in the demos provided by Beau that the picture seems absolutly clear.
I am using PAL mode (bit 0 on _mode set to 1). Anyone else using PAL ?
(Assuming I have the right resistors, and doesn't screw up completely)
Don't visit my new website...
Although the Propeller PAL mode may be coded very closely to the "standard" (although there are several sub specs for PAL as well) it may well be that your TV just doesn't quite like the signal.· Do you have another set you can test it on?· The top few lines after the overscan can get "bent" and colour can phase in and out slightly with only minor timing variations between the code and tv set.
When I got my XGS, although it was tested on several PAL sets in the USA, I coudln't even get the PAL demos to show any colour without substantial modification.· I'm not sure how the Propeller handles the colour burst and the different frequencies for PAL/NSTC·so I can't comment on that.
Although I am English, wherever possible I will use NTSC as it is simply much more forgivng.· Not exactly a great solution, but if you can get a multi NTSC/PAL set or a NTSC set it may well save a lot of headaches in the future.
Beware the pink squirrel!
I tried the TV tests against two different monitors. The noise is the same on both.
I think I can get an NTSC monitor. I will try to see what happens.
It would seem very strange that the problem is *identical* on both sets.
That would seem to indicate the signal generation software/hardware rather than the tv? I'm still wating for my Prop, I'll let you know how it goes on my sets once it arrives.
Is it possible you have some device nearby such as a desk fan that is causing the interference?
However, if I connect other video input on the same table to the same TV I get a very clear picture. If there is an interference generator in the nearby should not affect *any* video source ?
By the way, I have tried also·an USB TV capture device (Avermedia USB 2.0) to get the picture but I get nothing. It·supports NTSC and PAL but it does not work. I suppose the video signal feature may be a problem for some TV devices.
I see 1.1K, 560, and 270 ohm.
Is this really an aproximation of a ratio of one; one-half; and one quarter?
That would ideally be 1.1K, 550, and 275 ohm.
If so, finding a way to tighten the values might help.
It's important that you clock the Propeller with at least 40MHz internally. Remember not to go over 10MHz on the external crystal, as the PLL always multiplies it by 16 and 160MHz is the upper design limit. If you're seeing noise, it might be that there is insufficient capacitance between VDD and VSS, but this is probably not the case.
There's a slight chance that the video generator on that particular COG could be broken since our tester is still evolving to trap more failures, and the video generators haven't been·tested yet. By the end of the month, this will be tested for. One way to find out if that COGs video is broken is to start up another COG at the very start of your application, so that when the TV driver is subsequently launched (perhaps within tv_terminal), it will go into the next COG, instead. This can be done with the following code:
VAR
· xcogstack long[noparse][[/noparse]8]
PUB yourapplicationsfirstpub
· cognew(xcog, @xcogstack)·· 'first like of code in first PUB
· tv.start (or term.start(pins))
PRI xcog
· repeat·· 'loop forever
If it turns out that the video generator is bad, we'll get you another chip right away.
Chip Gracey
Are you using a noisy switching power supply or a wall transformer with inadequate filtering? (Some "DC" wall transformers -- primarily those designed for battery charging -- don't have filter caps.) Either one could be allowing noise or "hum" on the 3.3V rail, which would result in the behavior you're seeing. If you have a scope, take at look at your 3.3V line, and make sure it's rock solid and noise free.
1+1=10
It just occurred to me that some RCA connectors are not very secure. The ground lead is a solder tab that is held by a nut. If you have that kind, just try tightening the nut.
This all could be a loose ground wire.
I have a DLP-PROP and can't seem to get a stable NTSC or PAL image on anything from widescreen TV to professional grade composite monitor (NTSC & PAL).
The images are there and quite clear but there is no colour and the whole screen is jittery.
I do get some colour glitches, say two a second but it is a very short flash.
I have tried the example from Chip suggesting starting two cogs and I am no better off so I guess the video generators are fine.
None of the TV or VGA outputs signals are great, and I have double and triple checked my resistors - everything is as it should be.
The ONLY thing that I can think of now is the crystal speed of 6MHz which is generated by the on-board FTDI chip.
I've attached a modified program that I have been using, bear with me because this is my first day with the Propeller...
Coley
Thanks for the speedy reply, my schematic is as per the prop demo board
P12 --1.1k ----|
P13 --560R----|----Composite Video
P14 --270R----|
And of course a ground connection.
The supply is straight off the DLP-PROP which is supplied via the USB connector.
I've tried this on my home machine and my laptop with the same results.
All demo's run just fine but the video signal is screwed.......
Picture is more stable if I strip out the chroma but still slightly jittery.
Any ideas?
Coley
That's what made me think that it was a problem with the crystal....
Here's the DLP-PROP datasheet:
http://www.ftdichip.com/Documents/DataSheets/DLP/dlp-prop-dsv10.pdf
Chip Gracey
I should have been more precise when I said that it was a problem with the crystal.....
I will scope the output from the FTDI chip, it may be that it is not fit for the purpose of generating stable video signals.
I have ordered a starter kit from Farnell in the UK so I will wait until that comes and compare the two platforms.
I have to say though from first impressions and despite my 'problems' that you have done a fantastic job with the Propeller, it is phenomenal!!!
Thanks go to you and Mike for your help....
Coley
So it would seem as though the clock output from the FTDI chip was just not stable enough to generate a good video signal.
I would say the DLP-Prop board is good just not quite good enough for time critical applications.
It will be winging it's way back to FTDI in the morning.
Coley
Double checked against the 5MHz crystal on the Prop Demo board and it was rock steady as expected.
It would seem that when first started up the FTDI gives out as near to 6MHz as I can tell but once attached as a USB device everything goes awry....
It could just be faulty I guess, I will give them the benefit of doubt until i get a reply from tech support.
Coley.
I did get the graphics demo to work with one of the platforms, but TV text, and Terminal are out!
The only way I have gotten it to work is in broadcast mode with TV graphics. The TV terminal & Text I have never got right. It seems ,with the Graphics in broadcast mode, the further away from the prop I take it the better the reception.
At any rate, I got it at a Flea market for $5 dollars to make an alarm clock out of it with the Propeller embedded in the battery compartment. The Radio in it works fine so it isn't a complete loss. My first attempt at it used a 6Mhz crystal so if that was better, the other flaws in my system wouldn't let me see it.
