Current on 5v Vdd Basic Stamp I Rev Dx
Donivan
How much current does the Basic Stamp I Rev Dx board have available to outside components on its Vdd pin? I want to use this for a 5v Relay (about 90 ma) but can't find the specs of the on-board 5v voltage regulator.
Donivan
Donivan
·· 90mA is definately too much.· Always try to use an external power supply to power devices like that.· Especially inductive devices.· Have the BASIC Stamp drive them through something like a transistor, not directly.
csavage@parallax.com
Jon Williams
Thanks!
P.S. Do you know how much I can actually draw from Vdd without it being a problem?
·· This is a quote from our website knowledge base.
How much current can the BASIC Stamp microcontroller’s on-board regulator provide?
The built in 5-volt regulator on the BASIC Stamp 1 module and BASIC Stamp 2 module can supply 50mA of current if powered by a 12-volt source. The BASIC Stamp 1 module consumes 1mA leaving 49mA available to power external devices not including any devices connected to the I/O pins.
