(URGENT PLEASE) Connecting 2 BS2 boards togther
I have a problem htat i want to use 2 flexinol wires at the same time on my BS2 boards, the problem is that i dont have enough power to make them both work at the same time. It happens that i have 2 BS2 boards, so i was thinking of connecting both of them together so that one stamp can give the commands to the other board, could you please tell me how to do that and what precautions i have to take in order not to fry both boards,
Thanks alot.
Thanks alot.
Don't do that.
Use another regulator.
A 7805 doesn't cost much, and it can deliver a whole Amp.
Don't visit my new website...
For example, you might have a 9V battery powering your BS2 board and a separate battery pack of 6 D-cells (9V total) to provide the power for the Flexinol wires. The grounds of both batteries would be the same but you'd only provide the 9V from the D-cells to the above-mentioned 7805 regulator. The output of the 7805 would then be the "Vss" for the Flexinol wires and their driver transistors ONLY.
