Basic Stamp Add on Board
I'm working on an add on board for a Basic stamp.· It requires too much power to drive directly from the stamp's regulator so I'll put it's own regulator on the board.· My question is what should the max voltage be? I was thinking it should be 9v.· Is that right?
What do other people do for regulators on stamp add on boards?
Thanks.
www.speechchips.com
Speech & Video IC's for BasicStamps
Thanks.
www.speechchips.com
csavage@parallax.com
Right. I didn't phrase that correctly. I want to use the same input voltage as whatever is powering the stamp. What is the max voltage of the regulator on the stamp?
Thanks.
www.speechchips.com
Remember to connect the externally regulated 5v power to VDD, pin 21 (on the BS2p that I'm using), not to VIN, pin 24. I'm using a LM317 regulator. If you use the LM317 note the regulated output voltage is on the tab, so don't screw it down to a metal case. - Andy -
The limiting factor here is how much power (aka heat) the regulator can dissapate before it over-heats. Now, Power is Voltage Times Current (P = IV). Say you're putting 9 volts across the regulator. It has to drop 4 volts, to get your nice fixed 5 volt output. Now, if you pull 1 amp through your regulator, 1 Amp * 4 Volts == 4 Watts, which is a lot, but doable.
If you're using a 12 volt supply, supplying that same 1 amp at 5 volts requires dropping 7 volts across the regulator. Now you're at 7 watts -- I think the practical limit is 5 watts, but you can look up the LM7805 docs to see for sure. Also note all that heat is 'wasted' power -- which you may not care about if powered from a wall-wart, or could be a big deal if battery powered.
Bottom line -- 7.5 or 9 volts are very nice values to start with. Note also the LM7805 requires at least 1.5 volts across it for it to regulate -- any lower than that, and your output voltage drops. Note also the LM3840-5 is a "low-drop-out" regulator, which only requires like 0.5 volts across it to regulate. But it costs $3.00 versus $1.50 or so for the LM7805.
Stamptrol - The PT5101N sounds useful but is far too expensive for what I'm doing.
www.speechchips.com
