keystrokes to non-debug window
I don't want keystrokes to go to a debug window, but to the front application.
For example, if I make Notepad the foremost application, can the Stamp board send keystrokes to that app?
Is this possible?
Basically I am asking if a Stamp board can send keystrokes to the computer itself?
Is this possible?
Jon Williams
But you must have an intermediary program which reads the serial port, and knows enough about Windows to interface with the Windows run-time environment. That being true, you might as well put the 'keystrokes' into the intermediary program in the first place.
Now, I understand there is a chip that will provide an interface between a BS2 and a PC keyboard port, and send 'real' keystrokes into your PC. I've never used it though.
