SX/B I2C Command — Parallax Forums
SX/B I2C Command
RsadeikaRsadeika Posts: 3,837
edited 2006-05-03 17:04 in General Discussion
I have the I2C_UART demo board, which has an EEPROM and the SX28 on one I2C buss. The question is, using SX/B I2C commands, how can I access either the SX28 or the EEPROM. The board contains two SX28's which are hard-wired via I2C line, and the EEPROM, which is also hard_wired on the same line.
I would prefer to have both SX's·be running in SX/B. I saw a snippet for accessing an EEPROM, using SX/B, and the SX/B code uses A0 as the ID for the EEPROM, is this a given for all EEPROM's. And is their a way of giving the SX28 an ID that the I2C command will understand within SX/B code.
This does not pertain exclusively to the I2C_UART demo board, I can see using something like this on two seperate boards.
Ray
    edited 2006-05-03 13:51
    The I2C instructions in SX/B are very generic and can be used for anything. $A0 is indeed a generic ID for memory devices, but you should never count on that -- ALWAYS download and read the docs for the device in question. You'll find slightly different addressing schemes for various memories.
    I posted our Serial InkJet Module code here several months ago -- it contains I2C routines for download and pulling character maps from an onboard EEPROM.
    Jon Williams
  • JavalinJavalin Posts: 892
    edited 2006-05-03 16:05
    Also,
    SX/B does not allow the SX to be a I2C slave!
    James
    edited 2006-05-03 16:13
    Sorry, I should have been clear about that, James is right. What I meant to say is that you can do any (7-bit addressing) master operations with the SX/B I2C -- it just takes a bit of code. It's a good idea to encapsulate the SX/B I2C instructions in subroutines so that they only compile once.
    Jon Williams
  • RsadeikaRsadeika Posts: 3,837
    edited 2006-05-03 16:22
    My post was a poor attempt at probing for some info as to what the next version of SX/B is going to contain. Their was some vague references to·this in an earlier thread somewhere in this forum, but I figured that by now something else could get disclosed.·I was·really trying to get it verified that SX/B will not have any slave capabilities in the next version, or any version in the NEAR future.
    I wanted to make sure of this point before I start developing slave capabilities in asm for one of the processors, I was hoping to avoid that, but ...
    Ray
    There are no changes to any of the I2C functionality, nor is it planned. If you want to create an I2C slave you need to hand code it.
    Jon Williams
