Dedicated SOUT
Is the dedicated serial pin for the [url=mailto:BS@p40]BS2p40[/url]·also 16 or is it different since it has more pins..· I am trying to use the SERIN command instead of the DEBUGIN command in order to use its timeout function.
' {$STAMP BS2p}
SERIN Rpin, 16468, 500, timeout, [noparse][[/noparse]DEC switch]
Does anyone know if·the Rpin·for the·BS2p40 is also 16?
' {$STAMP BS2p}
(The i/o pins are labelled p0-p15, and x0-x15, or 0-15 in the "current block",
·so "16" is not part of either range.)
PAR
