No really.· The GP2D12 outputs a non-linear analog voltage related to the distance of an object it detects.· You really should use an ADC0831 or similar to read it.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Chris Savage Parallax Tech Support csavage@parallax.com
You haven't said what your application is- so advice on which sensor to use is based on some conjecture on the advisor's part. Here are some things to consider.
GP2D15- simple (1 pin) digital interface. easiest to interface, rapid response, returns digital (on-off) reading when object is within factory predetermined range. Runs continuously, so it is a bit of a powerhog.
GP2D05- 2 pin interface. rapid response. returns digital (on/off) reading. Distance adjustable with dial on unit. Only runs when queried, so it uses less power. slightly slower response than GP2D15, since you need to query the unit each time.
GP2D02- 2 pin interface. Slow response(plan on 10 or fewer queries per second). serial interface, so it will give you range to object.
GP2D12- 1 pin interface. Runs continuously. intended to be used with an ADC. (recommend a cap to ground on the signal line to level out readings).·Response··time related to size of signal leveling cap. can be used with a voltage comparator·(alternatively a voltage bridge and Scmitt trigger buffer)to deternine a digital threshold that can be read with a Stamp.
There are also long range versions of most of these.
Here is an interesting, and hopefully helpful article about linearizing the readings when converting from the Sharp GP2D12's analog voltage to distance:
http://www.acroname.com/robotics/info/articles/irlinear/irlinear.html
Bruce Bates
<!--StartFragment -->
TIm
Here is a web page with some info on using the Sharp GP2D12:
http://madlabs.info/gp2d12/sharp_gp2d12.shtml
You *might* be able to use the RCTIME command, but resolution will be poor.
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
The Sharp GP2D02 I/R distance sensor has a serial interface which easily interfaces with the PBASIC Stamp, and has all of the same characteristics as the GP2D12. Here are some applications notes:
http://www.acroname.com/robotics/info/examples/GP2D02-4/GP2D02-4.html
Bruce Bates
Hope that gets you started.
