Getting Syntax error when I use word PIN
Newbie here.· Just starting with StampWorks Experiment Kit.· Installed latest editor v2.2.5.·
When I enter code for the first experiment:
[noparse][[/noparse] I/O Definitions ]
AlarmLed····· PIN····· 0··············· ' LED on P0
When I run the syntax checker, I get the message:
Expected ':' or end-of-line
and the word PIN is highlighted in blue
It's like it doesn't like the keyword PIN.
It seems that I can avoid using I/O definitions of the type PIN, but that is not in keeping with the "Writing Code like a PRO" style conventions.
What am I doing wrong?
Add the following line to the beginning of your program:
'{$PBASIC 2.5}
(note the curley brackets) and that will take care of it. You can also use one of the short-cut buttons at the top of the PBASIC Editor interface to do the same thing. If you mouse-over each button, you will see which one to use. The PIN command was a PBASIC 2.5 addition.
Bruce Bates
<!--StartFragment -->
Sid Weaver
Do you have a Stamp Tester yet?
