You should be abble to get a serial to USB adapter for a really good price at a local electronic store·(I got mine for $19.99).· It was by a company called: "Cables unlimited".· Hope that helps.
There is always an answer.
There is always a way.
There is always a reason.··· -SciTech02.
Beware of usb 2 serial products not sold by Parallax, some work, some dont. It must support RS232 handshaking to be able to program the stamp, and quite a few don't.
Even the ones that do support the handshaking signals can have poorly written drivers or lack of support for older functions of the serial protocol which aren't used much anymore, such as being able to perform a break condition.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Chris Savage Parallax Tech Support csavage@parallax.com
This indicates you have the default COM Port set to something else, so it ignores it unless you specify in a directive.· That is an easy fix.· Go to Edit, Preferences, Editor Operation and set the default COM Port to AUTO.
Serial to USB adapter
1+1=10
