If anyone can please tell me how to connect a ISD2560 single-chip Voice Record/Playback system modulator to a toddler robot. I need a schematic for it and how to use it PLEAZZZZZZZZZZZZ
That's fine, and the purpose of this forum is to support Parallax product, so you'll have to ask your selected vendor for assistance with it. If they won't provide you with the information you need, how can we possibly help interface to it?· Once you get schematics and/or connection information from them, we can probably assist; at this point it would just be educated guessing.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Jon Williams Applications Engineer, Parallax
Click the resources tab of the link you posted·(also follows this post) for pinouts and tech specs and other docs·on this particular product. You won't likely find a schematic for an end product like that, I believe you are referring to the pinout, which as I indicated is avalable at the link. There is also a brief user manual that describes how to use this product. I only glanced at it, but it seems that you only need to pull certain pins high/low for basic operation.
This describes interfacing with a microcontroller, but not the Stamp,·and has example circuits.
Another route is to use a hybrid approach of building a pushbutton-controlled type of·recorder board and use the Stamp to control record and playback by using its outputs to substitute for the control pushbuttons, as in http://www.robotics.com/arobot/aspeech.html
http://www.technologicalarts.ca/catalog/product_info.php/cPath/21_47_62/products_id/64
this is the site i ordered it from and it as no schematic on the site
http://www.parallax.com/detail.asp?product_id=29111
Jon Williams
Jon Williams
http://www.technologicalarts.ca/catalog/product_info.php/cPath/21_47_62/products_id/64·
John
Manxstamp,
Isle of Man, British Isles
