How would I build this on a breadboard?
A_Guy_Who_
R1 = 1K Ohm Resistor
L1 / L2 = Leds
D4-7=1N4001
Probe = Wire
If someone could actually save the breadboard picture to their desktop and draw the parts on it for me would be great.
How would I build this:
On a breadboard like this:
L1 / L2 = Leds
D4-7=1N4001
Probe = Wire
Start by calling the red bus Probe 1, Blue bus Probe 2. Top red is probably separate from bottom red. Same with top/bottom blue.
In each column 1 thru 30, a,b,c,d,e are tied together with each other; f,g,h,i.j are tied together with each other. Each column is separated from the other columns.
It is called a Experimenting Breadboard, after all. So experiment!
Forget the diodes D4 through D7, the LED's already do that for you.
You have already done it!.... essentially the components could be laid out almost identical to how you have it in the schematic that you provided.
Here is a simplified schematic:
....But as 'stamptrol' mentioned, you should experiment.
Beau Schwabe
IC Layout Engineer
csavage@parallax.com
You don't have to follow the exact hole placement, you just have to make sure the connections are made in the same row (the numbers), where they are in the column (the letters) isn't important, or which row number you use.
The green, lavender, magenta and yellow lines show how holes are connected internally to the breadboard, holes on the same color are connected to each other, holes of a different color are not connected. This pattern is repeated for the entire board. The busses (red and blue) are connected as shown by the red and blue lines over the holes, this is repeated for all bus lines.
1+1=10
Chris I.
1+1=10
Here's how it looks:
1+1=10
