Can BS2 ping IP address
I want to build a simple device that will keep my network connection up by using a BS2 to ping an external IP address (like 66.102.7.147 -- which is google) every ten seconds and if it fails for 5 tries in a row, then turning off a relay (to power cycle my dsl modem), waiting five seconds, and then turning the relay on again.
Would this require a PINK module? Or can a BS2 do it by itself? I could write the code and build it if it were serial info rather than a ping command. Would it be easier to just connect the stamp to a serial/ethernet interface like a picotux (www.picotux.com)?
Gwyan
Gwyan
Application data
Presintation data
Session data
Transport data
Network data
Datalink data
Physical media
good luck though and let us know if you where secessful
Post Edited (Grant_O) : 4/24/2006 11:41:44 PM GMT
