adding GPS
I want to be able to get my position via GPS.
What type of GPS module would I need to get?
What other equipment would i need?
Any information and suggestions would be wonderful!
You might try a Motorola Oncore module. They are often on ebay for sale at very reasonable prices. I also bought an active antenna for it, total was around 30 dollars. I haven't actually done much with it yet, but I used Jon's code to read it and it all worked. I can't say how it is in actual use, just on the desk.
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
Can you give me a part list of the items I would need? (links to the parts, if possible)
I'm probably going to need assembly instructions as well...but we can save that for another post
I should note that I mounted my GPS on simple prototype board - this requires soldering the individual wires from the bare end of the ribbon cable to the protoboard. If you are using a PCB, a surface mount connector is available from SamTec as well, and you can just order the ribbon cable with connectors on both ends, instead of single-ended as I did. The programming is fairly simple using readily available examples on the Inet, as well as here
If you decide to go with this GPS unit , and need a bit of help or the part # number for the cable, feel free to email me at robert@hawaii.rr.com.
Here are some links :
http://www.sparkfun.com/commerce/product_info.php?products_id=163
http://www.sparkfun.com/commerce/categories.php?cPath=4_18
http://www.sparkfun.com/commerce/categories.php?cPath=4_86
http://www.samtec.com/
Edit: I attached a picture of my LassenIQ mounted on the protoboard of a CanSat (mimi-satellite)
Post Edited (Robert@HCC) : 4/29/2006 8:12:58 AM GMT
