high power battery charger
I want to use the board of education basic stamp and PWMPAL to control a 2500W buck converter to charge batteries. One of my ideas is to put the stamp at the output of the converter and sense the voltage to see if it is at the charging voltage (~12 volts) then modulate a series of buck transistors as needed. I plan on using a voltage divider in parallel with the battery to protect the stamp. The battery has an internal resistance of 4milli-ohms. Will this work? Is there a standard way to protect the stamp from high currents?
I will use the voltage divider. Thank you for the reassurance.
Since my posting I have decided to go with the SX-key. I will program it to input an analog signal and PWM. The extra speed of the SX-key minimizes the size of the buck inductor and the SX28 chips are $3.
Did you isolate the charging of the batteries -- Did you use diodes or an eight output led transformer to separate the batteries? Or did you not isolate them and hook up the battery terminals directly to the output of the rectifier with wires.
