basic stamp timer — Parallax Forums
basic stamp timer
amuszemeamuszeme Posts: 13
edited 2006-04-25 01:51 in BASIC Stamp
can the bs2 be programmed to follow a loop for a certain number of seconds/minutes and then fall out of the loop when the timer reaches its count?
    edited 2006-04-24 01:07
    Basically, I want to say, emphatically, "Yes, you can," but right after doing so you're going to drop the other shoe and change all that.· So, what's up Doc?· What's the big(ger) picture?· More details, please.
  • amuszemeamuszeme Posts: 13
    edited 2006-04-24 01:22
    That's it...all i want to do is make a loop that will allow me to run a servo for a certain amount of time and I just need to know how to do it. I have a boe-bot that I need to operate for a certain time unless the reset button is pushed.
    edited 2006-04-24 01:32
    OK (you provided more info).· I'm not a real DO...LOOPer, but here's what I'd do:
    FOR A = 0 TO 2000
    IF INPUT = 1 THEN ZAP
    PAUSE 10
    A = A + 10
    NEXT
    ZAP:
     stops the servo
    You start the servo running before executing this routine.· It will run for about 2 seconds.· It checks for an INPUT every 10msec.· If it gets an INPUT then it goes to "ZAP" and turns off the servo.· If it runs to the end of A (2000), then it falls through to "ZAP".
    edited 2006-04-24 01:37
    Thank you PJ...I will try it.
    edited 2006-04-24 01:39
    It's a pseudo-codey thing I did, for sure, but I figure you get my meaning.
    edited 2006-04-24 01:48
    Yeah, I got you. I'm gonna try it and let you know how it works after I finish testing the entire program.
    edited 2006-04-24 02:09
    Since I run a servo from an oscillator with a variable PW· that I enable/disable (I do different things), looking at it closer, you should make the SERVO-kick part of the routine.· It'll recur within the refresh time.
    edited 2006-04-24 17:29
    For timing of a routine using the DS1302 see the following thread.· It relates to using the DS1302 as a countdown timer.
    http://forums.parallax.com/showthread.php?p=550292
    csavage@parallax.com
    edited 2006-04-25 00:42
    Hi EveryOne
    Here is the DS1302 as a countdown timer and this the·routine that i used named
    DS1302_VCR_Camera2.bs2 in the Attachment below
    I also have this routine· DS1302_Camera_1.bs2 Attachment below
    I hope this helps you in what you want to do
    Sam
    ······································································ jumpin.gif
    Thank you Sam, Chris and everyone else. You have been a big help.
