Is something wrong!!
I have been getting bad results from the microcontroller. It seems that when I do Ch1=1 I get highs on all my I/O. My program says only Ch2. When I do Ch3=1 I get lows on all I/O. I have not got past that point in the troubleshooting.
??? Is there something wrong with my code or microcontroller ???
' File......
' Purpose...RC CONTROL OF Unmanned Search And Rescue Vehicle (USARV)
' {$STAMP BS2}
' {$PBASIC 2.5}
' Program Description
'Control USARV using 4-Channel R/C
' I/O Definitions
Ch1 PIN 12 ' Input channel used to receive forward'
Ch2 PIN 1 ' Output channel used to drive forward'
Ch3 PIN 13 ' Input channel used to recieve reverse'
Ch4 PIN 2 ' Output channel used to drive reverse'
Ch5 PIN 14 ' Input channel used to receive left'
Ch6 PIN 3 ' Output channel used to steer left'
Ch7 PIN 15 ' Input channel used to receive right'
Ch8 PIN 4 ' Output channel used to steer right'
' Program Code|
begin:
DO
INPUT Ch1
INPUT Ch3
INPUT Ch5
INPUT Ch7
IF ( Ch1=1 AND Ch3=0 ) THEN : GOSUB FWD 'Drives USARV forward'
ELSEIF ( Ch1=0 AND Ch3=1 ) THEN : GOSUB REV1 'Drives USARV backwards'
ELSEIF ( Ch1=0 AND Ch3=0 ) THEN : GOSUB stops 'Stops USARV'
ENDIF
IF ( Ch5=1 AND Ch7=0 ) THEN : GOSUB LFT 'Turns USARV left'
ELSEIF ( Ch5=0 AND Ch7=1 ) THEN : GOSUB RHT 'Turns USARV right'
ELSEIF ( Ch5=0 AND Ch7=0 ) THEN : GOSUB NOTURN 'Drive straight'
ENDIF
LOOP
' Subroutines
FWD:
HIGH Ch2
LOW Ch4
PAUSE 50
RETURN
REV1:
LOW Ch2
HIGH Ch4
PAUSE 50
RETURN
stops:
LOW Ch2
LOW Ch4
PAUSE 50
RETURN
LFT:
HIGH Ch6
LOW Ch8
PAUSE 50
RETURN
RHT:
LOW Ch6
HIGH Ch8
PAUSE 50
RETURN
NOTURN:
LOW Ch6
LOW Ch8
PAUSE 50
RETURN
' File......
' {$STAMP BS2}
' {$PBASIC 2.5}
' I/O Definitions
' Program Code|
begin:
DO
INPUT Ch1
INPUT Ch3
INPUT Ch5
INPUT Ch7
ENDIF
ENDIF
LOOP
' Subroutines
FWD:
HIGH Ch2
LOW Ch4
PAUSE 50
RETURN
REV1:
LOW Ch2
HIGH Ch4
PAUSE 50
RETURN
stops:
LOW Ch2
LOW Ch4
PAUSE 50
RETURN
LFT:
HIGH Ch6
LOW Ch8
PAUSE 50
RETURN
RHT:
LOW Ch6
HIGH Ch8
PAUSE 50
RETURN
NOTURN:
LOW Ch6
LOW Ch8
PAUSE 50
RETURN
I think you want to remove all of the COLONS from all of your IF and ELSEIF statements:
Change -
ENDIF
To this -
IF ( Ch1=1 AND Ch3=0 ) THEN GOSUB FWD 'Drives USARV forward'
ELSEIF ( Ch1=0 AND Ch3=1 ) THEN GOSUB REV1 'Drives USARV backwards'
ELSEIF ( Ch1=0 AND Ch3=0 ) THEN GOSUB stops 'Stops USARV'
ENDIF
Bruce Bates
<!--StartFragment -->
