measuring battery usage
I have a BOE-BOT that has alot of stuff added to it. The things that run off the main BOE are the BOE, (4) Parallax servos, "Gazbot" sensor·system that has·2 bump switches and a IR sensor, (3) Parallax "QTI" line sensors and a R/C radio receiver (50 mA). I am using a 1100 mAh NiMH 7.2 battery to run the main BOE. While the program runs fine, it will run only a little over 2 mins, then it starts to act up. Stop and recharge the battery and then it runs OK for another 2 mins. I thought the system would run longer with that battery.·My question is how do I make something to measure low mA usage while my robot is running? I tried using a digital multimeter, but it would not let the BOE run. I am quessing that the internal resistance of the meter is·to high to pass enough current at 5V. Does anybody have any ideas on how to figure out what is using the most current?
······ Joe Fishback
-Robots are my friends-
······ Joe Fishback
You may have blown the fuse in your meter. Most meters have a seperate input jack for the red lead when measuring high currents. That seperate jack doesn't have a fuse so it should work if you use that jack.
Bean.
"SX-Video·Module"·available from Parallax for only $28.95 http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module"·available·for only·$49.95·www.sxvm.com
Available now! Cheap 4-digit LED display with driver IC·www.hc4led.com
"I reject your reality, and substitute my own." Mythbusters
