External Crystal — Parallax Forums
External Crystal
parskoparsko Posts: 501
edited 2006-04-24 16:40 in Propeller 1
Hello all,
Been brewing my own board. I purchased a "standard" crystal, 5.000MHz. But, can't verify if it will work. Making matters worse is that I can't find a datasheet. I have read consistantly about the XTAL crystal specifically. The one I have looks like a standard one, but the one's in the misc pictures shows a smaller style.
I will first start by asking:
Is the prop sensitive to specific external crytals?
-Parsko
    edited 2006-04-23 20:23
    My guess is that it is not sensitive. It would be harder to make it _not_ oscillate. The _accuracy_ of the oscillation will depend on matching the load capacitance.
    Tracy Allen
    www.emesystems.com
  • parskoparsko Posts: 501
    edited 2006-04-24 06:42
    So, would you gander that any 5MHz crystal will work?
    -Parsko
  • JavalinJavalin Posts: 892
    edited 2006-04-24 09:00
    edited 2006-04-24 12:45
    Javalin,
    I asked again because:
    a) searched and couldn't find said post
    b) remembered reading said post a while back and still not knowing if what I had would work.
    The guy said it was a "standard" 5Mhz crystal. If he had said this is a "standard" cap screw, I would have known what he said, as I am a mechanical engineer and know what a "standard" cap screw is. BUT, not sure what a "standard" crystal is. [noparse]:)[/noparse] [noparse]:)[/noparse]
    Sorry if this is repetetive.
    -Parsko
  • cgraceycgracey Posts: 14,280
    edited 2006-04-24 14:57
    The 5.000MHz crystal we've been using at Parallax is ECS-50-20-4, or Digi-Key part number X410-ND.
    Chip Gracey
    no worries.
