Help with Circuit
I am wanting to build an infrared object detection system for a bot I am working on, and I was wondering if the following would work, as I am more of a mechanical person than electrical.
I bought a matched infrared emitter and detector from radioshack and came up with the circuit attached.
Please have a look and tell me what you think.
Nelson
Nelson
bmp
289K
Nelson
The benefit of the 'Decoder' approach is that the IR-Decoder continues to output a signal for a short period of time after the 'blinking' has gone away. This short period of time lets you use a
FREQOUT IR_Pin, 38500
PULSIN IR_Pin2, PulseVal
code. The "PULSIN" statement measures any recieved reflection. And the 38500 blinking help reduce the effects of Flourescent lights and sunlight.
Using the 'matched' device you've gotten from Radio shack, I'm not sure it's possible to read the reflection this way.
Nelson
Nelson
You want to have a good physical connection, first.· Then, with your tip heated fully, melt some solder on it; then place that tinned tip to the joint with your solder at the ready and touch it to the heating joint and remove the tip altogether once the solder flows.
Best to practice on bits of wire.
Nelson
Also having the proper tools greatly helps, for instance using an iron designed for plumbers is going cause you major headaches. If you need recomendations on which type of iron to get given your budget, ask.
1+1=10
