Parallel to Serial
I've been looking recently throught the intregrated ciruits, and I've spotted this... "74HC165 Parallel to Serial" on http://www.parallax.com/detail.asp?product_id=602-00010
Is this the one that may make your Parallel LCD into a serial so only one pin could be used?
If so, please tell me how to connect, because there's no data sheet privided
Vladimir
Vladimir
http://www.parallax.com/dl/docs/cols/nv/vol2/col/nv62.pdf
Jon Williams
Vladimir
Here is another solution. Shoot over here first:
http://www.elabinc.com/
Punch up "EDE IC's" and then look at the "LCD Screen Control IC's", then at the EDE-700 and the EDE-702 IC's specifically. Now you can take any compatible LCD and use it serially.
Bruce Bates
<!--StartFragment -->
Jon Williams
Jon Williams
