get data from a PaK11 and dispaly it on an lcd
I am using the Homework board and Am trying to get a program to·get data from a·PaK11 and dispaly it on an lcd. I have a chunk of code that will display information on a LCD (which i have hooked up)
' File...... Parallel_LCD_2X16.bs2
' Purpose... Parallel LCD Display Demo
' Author.... Parallax, Inc.
' E-mail.... support@parallax.com
' {$STAMP BS2}
' {$PBASIC 2.5}
[noparse][[/noparse] Program Description ]
' This program demonstrates using a Hitachi-compatible Parallel LCD Display
' This code works with the BS2, BS2e and BS2sx
[noparse][[/noparse] I/O Definitions ]
E PIN 0 ' Enable Pin For LCD
RW PIN 2 ' R/W Pin For LCD
RS PIN 3 ' LCD Register Select
' 0 = Instruction, 1 = Text
[noparse][[/noparse] Variables ]
char VAR Byte ' Character To Send To LCD
inst VAR char ' Induction To Send To LCD
index VAR Word ' Character Pointer
temp VAR Byte ' Temp Variable
[noparse][[/noparse] EEPROM Data ]
DATA "Hello, this is the LCD demo." ' Message To Send To LCD
[noparse][[/noparse] Initialization ]
Initialize:
LOW RW ' Set LCD To Write Mode
OUTS = %0000000000000000 ' Set All Output Low
DIRS = %0000000011111111 ' Set I/O Direction
GOSUB Init_Lcd ' Initialize The LCD Display
[noparse][[/noparse] Program Code ]
Main:
FOR temp = 0 TO 27 ' 28 Characters
IF temp = 15 THEN ' Check For End Of Line
GOSUB Next_Line ' Jump To Next Line
ENDIF
READ temp, char ' Read Next Character From EEPROM
GOSUB Send_Text ' Send Character To LCD Display
NEXT
END
[noparse][[/noparse] Subroutines ]
Init_Lcd:
PAUSE 200
OUTS = %00110000 ' Reset The LCD
PULSOUT E,1 ' Send Command Three Times
PAUSE 10
PULSOUT E,1
PAUSE 10
PULSOUT E,1
PAUSE 10
OUTS = %00100000 ' Set To 4-bit Operation
PULSOUT E,1
Inst = %00101000 ' Function Set (2-Line Mode)
GOSUB Send_Inst
Inst = %00001110 ' Turn On Cursor
GOSUB Send_Inst
Inst = %00000110 ' Set Auto-Increment
GOSUB Send_Inst
Inst = %00000001 ' Clears LCD
GOSUB Send_Inst
Inst = 14 ' Set Cursor To Underline
GOSUB Send_Inst
RETURN
Send_Inst:
LOW RS ' Set Instruction Mode
OUTB = Inst.HIGHNIB ' Send High Nibble
PULSOUT E,1
OUTB = Inst.LOWNIB ' Send Low Nibble
PULSOUT E,1
HIGH RS ' Set LCD Back To Text Mode
RETURN
Send_Text:
OUTB = Char.HIGHNIB ' Send High Nibble
PULSOUT E,1
OUTB = char.LOWNIB ' Send Low Nibble
PULSOUT E,1
PAUSE 100
RETURN
Next_Line:
Inst = 128+64 ' Move Cursor To Line 2
GOSUB Send_Inst
RETURN
I Have the Pak11 bread boarded up with the mouse connected to it. I just need to get the stamp program set up so that i can have the lcd dispaly the data and so that the data displayed is the running total.
http://www.awce.com/pak11.htm
here is a bit of code but it gives errors.
http://www.awce.com/pak11note.htm
I am new to Stamps I have dabled (newbie!!) with Pics and MBASIC.
I know that these are just bits of other peoples work. I am looking to get this running so that I can go through the code and understand it. I can then go through it and understand it. I have been learning Mbasic and have been going through a few books I just got (project by project). I have done some looking and havent fonud much for this.·I have gone through the "what is a microcontroller book".
Also sorry for any spelling errors.
······ Mat
Post Edited By Moderator (Chris Savage (Parallax)) : 4/21/2006 3:51:14 AM GMT
' {$STAMP BS2}
' {$PBASIC 2.5}
Initialize:
Main:
ENDIF
NEXT
END
Init_Lcd:
PAUSE 200
PAUSE 10
PULSOUT E,1
PAUSE 10
PULSOUT E,1
PAUSE 10
PULSOUT E,1
GOSUB Send_Inst
GOSUB Send_Inst
GOSUB Send_Inst
GOSUB Send_Inst
GOSUB Send_Inst
RETURN
Send_Inst:
PULSOUT E,1
PULSOUT E,1
RETURN
Send_Text:
PULSOUT E,1
PULSOUT E,1
PAUSE 100
RETURN
Next_Line:
GOSUB Send_Inst
RETURN
······ Mat
Thanks!
csavage@parallax.com
Update:· I have the stamp showing me data now. I havent gotten it to give me a running tally yet though
