operator overloading
Java does not support· operator overloading natively.
The utility subjava converts a .subjava source into a .java source
that can be compiled.
For example, the file TestForFloat32.subjava
substitutions stamp.math.forFloat32;
public class TestForFloat32 {
·· public static void main() {
····· stamp.math.Float32 c1 = 1,· c2 = -5;
····· stamp.math.Float32 c3 = new stamp.math.Float32( 1 );
····· stamp.math.Float32 c4 = c1 * c2 / c3;
····· stamp.math.Float32 c6 = 7 * c2 / 8;
····· stamp.math.Float32 c7 = c3 + c4 / c1 - c2;
converts to file TestForFloat32.java
····· stamp.math.Float32 c1 = new stamp.math.Float32( 1),· c2 = new stamp.math.Float32( -5);
····· stamp.math.Float32 c4 = c1.multiply( c2 ).divide( c3 );
····· stamp.math.Float32 c6 = c2.multiply( 7 ).divide( 8 );
····· stamp.math.Float32 c7 = c3.add( c4.divide( c1 ) ).subtract( c2 );
To test this for yourself, you need to have installed the Java 2 runtime environment JRE
which you can download here:
http://java.sun.com/j2se/1.5.0/download.jsp
install JRE
copy TestForFloat32.subjava and subjava.zip to c:\program files\parallax inc\javelin stamp ide\projects
copy forFloat32.substitutions to c:\program files\parallax inc\javelin stamp ide\lib\stamp\math
open a command prompt window
move to folder c:\program files\parallax inc\javelin stamp ide\projects
give command
java -cp subjava.zip;"c:\program files\parallax inc\javelin stamp ide\lib"; subjava.SubJava TestForFloat32.subjava
That should generate the TestForFloat32.java file in folder projects.
I like some comments on this.
regards peter
install JRE
give command
regards peter
[noparse][[/noparse]TestForFloat32.subjava]
import stamp.math.*;
substitutions forFloat32;
····· Float32 c1 = 1,· c2 = -5;
····· Float32 c3 = new Float32( 1 );
····· Float32 c4 = c1 * c2 / c3;
····· Float32 c6 = 7 * c2 / 8;
····· Float32 c7 = c3 + c4 / c1 - c2;
[noparse][[/noparse]TestForFloat32.java]
····· Float32 c1 = new Float32( 1),· c2 = new Float32( -5);
····· Float32 c4 = c1.multiply( c2 ).divide( c3 );
····· Float32 c6 = c2.multiply( 7 ).divide( 8 );
····· Float32 c7 = c3.add( c4.divide( c1 ) ).subtract( c2 );
regards peter
that the variables used in a formula get changed.
So I figured a way to prevent this.
I wrote a small class that does Int32 math, but it has
methods that accepts 2 operands and returns a temporary
result.
In essence,
··· f = (a+b)-(c+d)*e+e;
gets converted to
··· I32.set( f, I32.add( I32.sub( (I32.add( a, b )), I32.mul( (I32.add( c, d )), e ) ), e ) );
I used a four level stack to do the calculation.
The output from the test program is:
Program Int32_overloaded_test
a = 0x01234567
b = 0x11112222
c = 0x01234567
d = 0x01110222
e = 0x00000001
calculate f = (a+b)-(c+d)*e+e
add:sp=1
add:sp=2
mul:sp=2
sub:sp=1
add:sp=1
set:sp=0
f = 0x10002001
program finished
Note that the variables a to e are not changed,
just as if longs are natively available.
I believe a four level stack (see I32.java) is sufficient for any expression
(my HP 15C calculator also uitilizes a four level stack).
The only requirement is that there must be an assignment.
So one can not use myfunc(a+b) but must use
c = a+b;
myfunc(c);
otherwise there will be stack errors.
regards peter
Post Edited (Peter Verkaik) : 4/27/2006 11:23:01 AM GMT
