fading leds? — Parallax Forums
fading leds?
meredth78meredth78 Posts: 18
edited 2006-04-20 23:20 in General Discussion
·I am trying to get an led to fade. I have done·it with the BS2, but I cant get it to work with the SX.
BS2:· ---WORKS---
·· ········ FOR pulsecount = 1 TO 255
··········· PWM led2, 255 - pulsecount, 3
··········· NEXT
SX/B: ---NOT WORKING---
··········· FOR pulsecount = 1 TO 255 step 5
············NEXT
HELP
-meredth78
Post Edited (meredth78) : 4/20/2006 5:01:40 AM GMT
  • BeanBean Posts: 8,129
    edited 2006-04-20 10:50
    Meredth,
    You cannot use math in the SX/B PWM command.
    You can do it this way...
    FOR pulseCount = 255 TO 1 STEP -5
    · PWM led2, pulseCount, 3
    NEXT
    SX/B is taking 255 as the duty and pulseCount as the duration.
    Bean.
    "SX-Video·Module"·available from Parallax for only $28.95 http://www.parallax.com/detail.asp?product_id=30012
    "SX-Video OSD module"·available from Parallax for only·$49.95 http://www.parallax.com/detail.asp?product_id=30015
    Available now! Cheap 4-digit LED display with driver IC·www.hc4led.com
    "I reject your reality, and substitute my own." Mythbusters
  • meredth78meredth78 Posts: 18
    edited 2006-04-20 22:12
    Thanks. Now I have another question.· With the BS2, when I am in a " do until" loop I can still use my other pins to do other things, kind of like multitasking. How do I 'multitask' like this with the SX/B?
    Post Edited (meredth78) : 4/20/2006 10:34:29 PM GMT
    edited 2006-04-20 22:37
    If you've got a working BS2 program you should be able to translate it -- with just a little effort -- to SX/B.
    Jon Williams
    edited 2006-04-20 22:53
    But, I can't get it to "Multitask" like the BS2 is doing.·The SX·gets stuck in the 'do until' loop and won't do anything else when the other pins go high.
    Post Edited (meredth78) : 4/20/2006 11:12:28 PM GMT
    edited 2006-04-20 22:56
    The BS2 doesn't multitask; what you can do is create a task-switcher and that is easily done with SX/B. Post your BS2 program and we can give you some hints.
    Jon Williams
    I know it's messy but I'm learning.
