data logger
I am in need of some help getting started with my basic stamp project.· I am very new to this rhelm and am having difficulty in knowing where to start.· A little bit about my application; The device I want to build is going to be a a data looger basically.· It is going to go inside a housing that will go through environmental tests.· It will have senors for monitoring shock, heat, and humidity.· It should also have a loop that sends an anolog signal into one side of a contact and monitor the signal at the other end of the contact to see if there are any opens that occur.· Does anyone have any references· or ideas of a good place to start?
www.parallax.com/dl/docs/books/sw/Web-sw-v2.0.pdf
