P64 package?
How will the 64 pin propeller will be packaged?
I am lobbying for the MQFP80. (80 pins, 20X14X2.7mm, .8mm pitch).
I wonder if this wire is hot...
Chip Gracey
I was hoping for something with a little wider pitch than .5mm though.
Some of the TQFP100 packages have .65mm.
Any chance of seeing something like that?
Are you concerned about PCB trace/space requirements or soldering, or both?
Chip Gracey
I am currently manufacturing and hand soldering my own printed curcuit boards.
I've had some success with the SSOP SX28's (like the one shown in my avatar), but 100 pins of .5mm pitch is pretty intimidating for people at my level.
.65mm would still be tough, but at least there would be a little room to breath.
1+1=10
I guess I'll have to try and see.
There is still the issue of making the board though, and aligning the chip properly on the traces.
Also the smaller traces are more likely to burn or lift off the board, and it only takes one of those to ruin your day.
I will start a poll to see what other people think.
It's amazing how sloppy the pasting can be and still produce clean joints and well-aligned parts. Surface tension is your friend! There're usually a few solder bridges that have to be removed, but solder wick makes that easy. Then there's the occasional solder ball that needs to be flicked off. Finally, a good scrubbing with 95% isopropyl alcohol and a toothbrush, and you're done.
I thought it was on hold, as the price for the software fix was to expensive ;(
It would be a great bonus if it was going ahead, especially with the projects that use extra SRAM [noparse]:)[/noparse]
http://www.propgfx.co.uk/forum/·home of the PropGFX Lite
I am now thinking that there seems a lot of interest with SRAM and these extra pins may make the Prop B a viable option. The SRAM could be placed on the B port together with an SD/microSD card, leaving the A port for all the existing things. And there are a lot of other things that could be done with the extra pins.
Would it be viable at say US$13 ?
My preference would be to not go tighter than 0.65mm pin spacing. It's a shame it won't fit into an 84 pin package.
· Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index)
· Search the Propeller forums (via Google)
It's OK that the Prop II comes in a LQFP-100 14mm x 14mm x 1.4mm-package
Will parallax provide an adpaterboard that spreads the PIN to 1/10 inch that it can be used in standard breadboards or dot-copper-PCBs ?
best regards
Stefan
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
