Pin's names
Hello again, I've been looking at this schematic @ http://www.parallax.com/dl/docs/prod/schem/bs2revf.pdf
and I don't understand several terms. If you do know then, please respond.
I am currently working on a homebrew BS2, and I just don't want to miss anything.
Can you please describe the following terms, or where I can find them:
SOUT
SIN
ATN
VSS
RES
VIN
VDD
Thnaks a lot
Vladimir
SOUT
SIN
ATN
VSS
RES
VIN
VDD
Thnaks a lot
Vladimir
SIN -·RS232-compatible input from the PC (used for programming, DEBUGGIN/SERIN)
ATN - used by the PC to reset the Stamp for reprogramming
Vss - ground
RES - Reset input (pulled-up on the module)
Vin - Voltage input to onboard regulator
Vdd - regulated +5v
Jon Williams
Post Edited (Jon Williams (Parallax)) : 4/19/2006 5:55:19 AM GMT
Vladimir
