chip pin problem
hi guys, this might not be related to BASIC Stamp, but since I am using it to make one (MAX232), here the thing i cannot figure out:
As I know, if a chip contains a hole on the side, it means that there is a pin # 1, but thats only in DIPs, i have SS
I've attached a picture, pins labeled with letters. Please respond, if you know, what letter is a correct pin. Something like, "A = 1, B = 2, etc"
Vladimir
Vladimir
max232 +ti
The first document presented is this one: http://focus.ti.com/lit/ds/symlink/max232.pdf and you'll find the answer on page 11; I can't tell you because you provided an low-res image and the marking on that chip is quite subtle -- though I believe it may be pin P.
Jon Williams
Vladimir
Jon Williams
i uploaded the image on geocities
http://www.geocities.com/vze4p6c2/DSC00252-1.jpg
Vladimir
Vladimir
1+1=10
Vladimir
1+1=10
