Melexis 90217 Hall Effect Sensor
-Hello All
I'm interested in using a hall effects sensor to measure rpms of an alternator. I used all of the download software from parallax and I assembled the circuit·but I can't get it to work. I've measured the output of·the sensor with > 1K/s rotations and·a basic·stamp2. The output is 0. The·sensor is mounted with the etched side facing the rotating alternator and·a·small magnet is mouted behind·the Melexis 90217·sensor to cause the Hall Effect.
-"...All I desire is knowledge; nothing more, nothing less..."
-CE
Post Edited By Moderator (Chris Savage (Parallax)) : 4/18/2006 5:19:30 PM GMT
-CE
csavage@parallax.com
Slowly but surely, we're getting there, inch by inch.
Now we realize you're using a gear tooth Hall Effect sensor IC. Now the question is what tooth on what gear? Most alternators I've seen have pulleys and belts, and no gears with teeth.
Bruce Bates
<!--StartFragment -->
