PBASIC48W/PE serin timeouts
We are using the PBASIC48W/PE OEM version of the pe with great success. However, we have recently seen a problem that we are still trying to narrow down. In particluar we would like to eliminate the PBASIC48W/PE as an issue. We wondered if anyone has seen a new behaviour of timeouts while using the serin command. The data rate is 2400, 8 bits no parity. We understand there was a firmware upgrade in recent parts (with a silver dot). We did find an incompatibility with the 2.2 editor, which was resolved with an update to 2.2.5. Is there also a possibility of sensitivity to the resonator frequency? It is very possible that other parts are the issue, we just wondered...
David Drake
David Drake
Tracy Allen
www.emesystems.com
DD
DD
