Basic Stamp OEM Modules vs Basic Stamp
Ok, dont laugh at me to much but here goes.
I have been working with a BOE for a couple of years. I have bought acouple of OEM Modules to work with. I know that I am slow, but I was comparing them the other day and noticed that the chip is different. Why is that? Where can I go to see what the difference are. Can I exchange them and get the same results?
What I am trying to do is run multiple stamps (two right now) but all I have is the modules with take up to much room. Thats when I found out the different between the two chips that I have. Do they program the same? Do I need the OEM module to program the chips?
Seems every time I think that I have learned something, I get confused.
Don "Ho"
Don "Ho"
·· Reading your message a second time made me think that perhaps you think you can use the large DIP IC on the OEM board as a BASIC Stamp, when in fact, you cannot.· That is only the interpreter, not the BASIC Stamp.· It takes all of the components on that OEM Module (Except the DB9) to make it a BASIC Stamp 2.
csavage@parallax.com
·· Yes, the BASIC Stamp 2 Module on the BOE-Bot is all the components on the OEM Module except the DB9 and two capacitors, which are located on the BOE.· Functionally they are the same.· Each contains an interpreter, 24LC16B EEPROM, voltage regulator (The OEM is beefier), RS-232 translation circuitry, etc.
Don "Ho"
