Need help with DC motor control
Help!!!!
I know this sounds rather silly, but I am having issues with motor control.· I am running 2 DC motors.· They need to be fairly quick.· the 45mA is not enough from the BS2 port.· I looked into integrating this H-Bridge:
http://www.zetex.com/3.0/pdf/zhb6718.pdf
I am having issues all over the place. (my project is now shorting, and resets are occuring...)
So is there a low-part count solution for just turning off/on motors using the source voltage?· I would like them to pull the current and voltage from the source (5V, 1A) but be controlled by the BS2.· It must be very quick and controlled.·
I would appreciate any help.
Shaun
Shaun
Jon Williams
csavage@parallax.com
I disconnected the H-Bridges from my circuit, and there are no longer any brown-outs...but I am now trying the following method:
I currently have a 74595 (Shift register) and a ULN2803AN darlington array...I was using this setup with Stepper motors on another project. I have the parts available, and I know they work so I think I'd rather implement them...
Could I Bi-directionally control the DC motors by connecting the (+) and the (-) of the DC motor to the Outputs of the Darlington array?
Jon Williams
