H/P Printer board - 5volts or 6volts? Which
I am very confused
Below is referring to the 96 dpi Serial Inkjet Printer Development Kit PDF. v1.1 updated 11/2005.
The schematics on pages 33 and 34 leave me with more questions than answers as the board is optionally powered by USB @ 5 volts·or a BOE @ 6 volts [noparse][[/noparse]see Sec 3.2, item #2 page 8].
I read the documentation and it says clearly that +6volts is expected to supply the board in the Sec 2.3 Technical Specifications on page 5.· But the diagram above it has a 5 volt power supply noted.
I read Page 4, Sec. 2.1 for Features and it says a Step-up 6 to 24 VDC power supply.
I look at the images of the physical·board and it shows +5volts as the input.
I can only guess that the range from +5 to +6 is okay BUT +5 IS SAFEST·and that the document should have given the range with the +6 maximum.· But I am not sure.
I have tried to list ALL of the references to voltages above so that you might resolve inconsistent language.
And, the USB power appears to only support the USB interface.
Post Edited (Kramer) : 4/18/2006 7:52:53 AM GMT
