Pic16c57
the PIC16C57 suposed to be pre-programed before it can be used, othervise it will not work. If that information is penetrable, how do you guys pre-program it and if it is possible to do so in home conditions?
Vladimir
Vladimir
Jon Williams
Vladimir
Jon Williams
Vladimir
And since the 16C57 lets you 'lock' the code inside it, so it can't be viewed from the outside, Parallax's intellectual property (that run-time engine PIC code) is protected -- in other words, NOT 'penetrable'.
When you 'program' your BS2 through the IDE, the IDE converts your PBasic source code into tokens, and invokes a down-load routine in the 'run-time' engine to read those tokens from the serial port, and load them into the eeprom for later execution. This means the 16C57 is NEVER modified by your code -- only the on-module eeprom.
