basic stamp maximum load
mithun
hi all,
could someone please suggest me about the following:
1. can I connect 3/4 ping sensors to the bs2 homework board.
2. can all of the sensors be activated at the same time? would it
·· exceed the 21 mA limit.
Based on the PING))) Documentation, each PING))) sensor requires 30-35mA per unit. The Homework Board has a 500 mA built-in voltage regulator, so based merely on those specifications, and presuming no other loads (poor presumption!), you COULD operate 14-16 PING))) Sensors without overloading the built-in power supply.
However, since the PING))) supplies a quantitative response (a numeric value) rather than a qualitative response (just HIGH|LOW or ON | OFF) having them "activated at the same time" doesn't make a whole lot of sense, as you'd have no way to field the individual readings, even if you could use them all simultaneously.
Bruce Bates
<!--StartFragment -->
You could power the Ping sensor thru it's own power supply circuit such as a 9V battery connected to a 7805 or 2940-5 regulator (along with input and output capacitors). Just remember to connect the grounds of the Homework board and the power supply circuit together.
