Motor Control w/ NPN Transistors
I have a DC motor that I took out of a cheap toy and also some NPN transistors around.·I·want to make a motor control circuit. Nothing fancy just 'motor ON' and 'motor OFF' (I don't even need a REVERSE function). Can anyone help me·design·a circuit like this that will interface to the·BS2?
The motor runs will run on 3 to 6V from its own, separate, power source.·The NPN transistors are similar to the ones from RadioShack:·http://www.radioshack.com/sm-npn-transistorspackage-of-15--pi-2062586.html
I tried building a circuit but I had no luck. This is my first time using transistors so I really·need some·help!
·on····· plane··········································, when catching ducks
"In this house, we obey the laws of thermodynamics!"
http://profiles.yahoo.com/jsmasterking
Post Edited (jsmasterking) : 6/5/2006 10:45:35 PM GMT
http://www.canton.edu/employee/hartle/elec243_S04/motor.JPG
csavage@parallax.com
Post Edited (jsmasterking) : 6/5/2006 10:45:20 PM GMT
On a H-bridge, the current has to pass through at least two transistors. Would the voltage drop be also as high?
Post Edited (jsmasterking) : 6/5/2006 10:44:56 PM GMT
